Hello
I tried the following command to split an MP4 video exactly, which means re-encoding the video stream, while keeping the audio as-is since it was good enough:
Even though I used the "-shortest" option, ffmpeg keeps going past the length of the video (which is about 15mn, and I stopped ffmpeg at around 23mn).Code:ffmpeg -ss 02:34:48 -i input.mp4 -b:v 200k -t 02:51:40 -c:v libx264 -vf scale=640:-1 -pix_fmt yuv420p -c:a copy -shortest -threads 2 -crf 20 -f mp4 output.mp4
Does someone why, and if there's a way to avoid needlessly re-encoding the audio stream as well?
Thank you.
Edit : I tried the "-to" option introduced in 2013, to no avail:
Code:ffmpeg -ss 02:34:48 -i input.mp4 -b:v 200k -to 02:51:40
Are you sure you are using a newer version of ffmpeg? Use ffmpeg -version
I guess you have read http://trac.ffmpeg.org/wiki/Seeking ? -
Yes, I'm using the latest and greatest.
I don't understand what this means:
"Note that if you specify -ss before -i only, the timestamps will be reset to zero, so -t and -to have not the same effect. If you want to keep the original timestamps, add the -copytsoption." -
You put '-ss 02:34:48' before the input thus ffmpeg starts at that point and the internal time stamp is now 0 at that point, so if you want to reencode from 02:34:48 to 02:51:40 you want to encode an interval of 00:16:52 and thus you should set the duration to 00:16:52 (-t 00:16:52).
users currently on my ignore list: deadrats, Stears555, marcorocchini -
Thanks for the info.
This worked as expected:
Code:ffmpeg -i input.mp4 -ss 00:05:00 -b:v 200k -to 00:05:30 -c:v libx264 -vf scale=640:-1 -pix_fmt yuv420p -c:a copy -shortest -threads 2 -crf 20 -f mp4 output.mp4
cant save video on windows movie maker past 76%? please help...
By arosemontages in forum Newbie / General discussionsReplies: 12Last Post: 16th Jul 2015, 07:15 -
VOB file displays "1 sec" length, is actually 29mins, plays full length but
By neonnebula in forum Newbie / General discussionsReplies: 2Last Post: 17th Feb 2015, 20:12 -
losing video length. PLEASE HELP!?
By nafaan in forum Video ConversionReplies: 2Last Post: 14th May 2013, 08:11 -
Video and Audio different length
By pchan in forum AudioReplies: 3Last Post: 15th Aug 2012, 03:46 -
Change length of an AVI. Reduce/Increase Frame Length
By Buzwinkle in forum Authoring (DVD)Replies: 4Last Post: 10th Aug 2011, 08:08
